Hi, i wan to use bean shell validator for must fill and range value. But for must fill value is not working. Here is my script:
if(Integer.parseInt(values[0]) == ""){
formData.addFormError("total_value", "Please fill the value"); //not working
return false;
}else if(Integer.parseInt(values[0]) < 3000){
formData.addFormError("total_value", "Value must between 30001-4000."); //working
return false;
}else if(Integer.parseInt(values[0]) > 4000){
return false;
else{
return true;
      Hi, it is impossible for a primitive type like int to be null or empty. You can try to initialize a variable with -1 (to indicate negative value) and assign Integer.parseInt(values[0]) to it, then check if it's still equal to -1 after the assignment.
      Try to refer to this: https://stackoverflow.com/questions/13747859/how-to-check-if-an-int-is-a-null
        Hi, the problem is that after converting the value into an integer, you are comparing it to an empty string. You need to perform comparison using the same types.
        1. jogetuser
          so instead use this how can i call the field id on joget?
          if(  ................   == "")
        2. Anders
          Try using values[0] directly without calling Integer.parseInt.
