Hi, form submission using ENTER is a default browser behavior. You could try to use custom JavaScript to disable that behavior like in https://stackoverflow.com/questions/5629805/disabling-enter-key-for-form.
Hi Anders!
Thanks for the response. I did look at very similar posts (even ones that locked it to bootstrap – https://stackoverflow.com/questions/59503468/prevent-bootstrap-form-to-submit-with-enter). However, the "tags" addition uses enter to "store" the tag.
Alternatively: I was looking at enabling the save key to be space vs. enter (which then your reference would work).
I'll keep poking at this.
Hello Everyone!
I'm still learning Joget in my part time. I know we have bootstrap under the hood, and REALLY like tags input; see here: https://bootstrap-tagsinput.github.io/bootstrap-tagsinput/examples/
I am trying to use Custom HTML in my form:
However, the default behavior of the Page/Submit button is to submit the form IF enter is pressed. Can we disable this via Custom HTML or in the properties?
Thanks!
Fro
Also looked at:
1. https://dev.joget.org/community/display/FORUM/how+to+disable+the+submit+button+in+form (i.e., close. but N/A)
2. https://dev.joget.org/community/questions/25593209/can-i-create-a-submit-button-on-a-form (From Anders we know Submit is AUTO created)
3. https://dev.joget.org/community/questions/25134119/to-disable-the-form-submit-if-the-condition-is-null-in-the-list (NULL is "ok", so this is N/A – it's not an error; and I really dislike having an "check ok to continue" portion of the form)
