Custom plugins are working fine on Windows environment, but we are getting below error when we upload to linux environement
INFO 18 Apr 2022 14:23:43 org.joget.plugin.base.PluginManager - Installed plugin aws_s3_upload_field-7.0.0.jar
ERROR 18 Apr 2022 14:28:57 org.joget.plugin.base.PluginManager - Failed bundle start for org.joget.aws_s3_upload_field [2]: org.osgi.framework.BundleException: Unable to resolve org.joget.aws_s3_upload_field [2](R 2.3): missing requirement [org.joget.aws_s3_upload_field [2](R 2.3)] osgi.ee; (&(osgi.ee=JavaSE)(version=11)) Unresolved requirements: [[org.joget.aws_s3_upload_field [2](R 2.3)] osgi.ee; (&(osgi.ee=JavaSE)(version=11))]
at org.apache.felix.framework.Felix.resolveBundleRevision(Felix.java:4368) ~[org.apache.felix.main-6.0.2.jar:?]
at org.apache.felix.framework.Felix.startBundle(Felix.java:2281) ~[org.apache.felix.main-6.0.2.jar:?]
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:998) ~[org.apache.felix.main-6.0.2.jar:?]
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:984) ~[org.apache.felix.main-6.0.2.jar:?]
at org.joget.plugin.base.PluginManager.startBundle(PluginManager.java:374) [wflow-plugin-base-7.0.28.jar:?]
at org.joget.plugin.base.PluginManager.upload(PluginManager.java:660) [wflow-plugin-base-7.0.28.jar:?]
at org.joget.apps.app.controller.ConsoleWebController.consoleSettingPluginUploadSubmit(ConsoleWebController.java:4689) [classes/:?]
at org.joget.apps.app.controller.ConsoleWebController$$FastClassBySpringCGLIB$$e1402d89.invoke(<generated>) [classes/:?]
at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:204) [spring-core-4.3.29.RELEASE.jar:4.3.29.RELEASE]
at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:668) [spring-aop-4.3.29.RELEASE.jar:4.3.29.RELEASE]
at org.joget.apps.app.controller.ConsoleWebController$$EnhancerBySpringCGLIB$$65132a9f.consoleSettingPluginUploadSubmit(<generated>) [classes/:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_312]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_312]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_312]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_312]
at org.springframework.web.bind.annotation.support.HandlerMethodInvoker.invokeHandlerMethod(HandlerMethodInvoker.java:181) [spring-web-4.3.29.RELEASE.jar:4.3.29.RELEASE]
Any help or suggestion would be appreciated
      Hi, the error mentions something about unresolved requirements in the Java version (osgi.ee=JavaSE)(version=11). Perhaps you should check the Java version difference in the 2 environments.
