Hi, I need to perform a crud operation in the community edition of the joget. Will it be possible to do that? Help me in this regard.
i need to edit the rows that is the main request.
      Hi, the CRUD element is not available in the community edition, but you can achieve the functionality by manually linking lists and forms. Try to refer to the sample CRM app that is bundled in the community edition to see that is accomplished.
