Hello,
I hope you are fine. Fetching data from list have different ways:
-You can match the ID, title, of specific data to be fetched.
-Furthermore, you can use form binders. Sequence would be data would be called from list to form.
-Furthermore, SQL database can be used to fetch data. Json file structure would be established to synchronize data.
Thankyou very much, I hope it helps(gives direction).
How can I get the data from a list?
E.g. I want to get the ID from the datalist, to parse back into a query to disable that row.
Regards,
