Hello
I want to have a subform with field already filled with values from an the parent form.
Is it possible and if it is how can i do it?
      There are many ways to do it. Maybe you can share what is the use case you have there.
      For example, in your subform, use the same table name. Then all fields with matching field IDs, will get populated right away.
