context attribute SOURCE_FILE_PATH(字段名) does not exist in the activity context - adding new attributes to activity context is not allowed
  1. xinweiwei
    你需要在流程设计器里面添加这个流程变量,表单的字段也绑定这个变量
    Hi, I cannot read chinese but based on the error message in the description, it would appear that you are trying to set a workflow variable SOURCE_FILE_PATH that does not exist. You need to define that workflow variable in the Process Builder first so that it appears in the Variable List.
