Hello guys of Joget Community
I´m developing an App on Joget Enterprise edition.
I have a form named TipoProjeto with fields Department (Multi-Select Box ) with "Department Options Binder".
In other form has a field Department (Multi-Select Box ) with id= "id_unidade"  and "Tipo Projeto" (Multi-Select Box ) with Default Form Options Binder and in "Advanced Options/Dependency/Field(s) to control available options" with id="id_unidade" value.
But, a dependency between fields "Tipo Projeto" and Department" not working.
Any suggestion or instruction to resolve this issue ?
Thanks,
Paulo Nascimento (Brazil)
      Not sure if I understand the issue. Are you trying to do  this? Dynamic Cascading Drop-Down List - Knowledge Base for DX 7 - Joget | COMMUNITY
      if so, you might be missing the grouping column.
