If I have the below table of name app_fd_classes and using #currentUser.groups.id# to check the logged-in user group (suppose each user must be in one group)
Class IDClass NameGroup ID
4class fourG-001
6class sixG-002
Can I have a hash variable that retrieves the class name of the currently logged-in user
Ex: If the logged-in user is in group 'G-001' then I want a hash variable to retrieve 'class four'
something like: #form.classes.ClassName[GroupId={currentUser.groups.id}]#
thanks in advance
  1. sushidetest
    have you figured this out? i have the same issue.
  2. Ian
    there's actually a new hash variable in jogetoss...might be what you're looking for GitHub - jogetoss/column-search-hash-variable
    Form Data Hash variables only accept primary key though. You could use Datalist Hash Variable instead, it has filters.
    Hash Variable - Knowledge Base for DX 7 - Joget | COMMUNITY
    or
    do something like
    Add Extra Attributes and Signature to User Profile - Knowledge Base for DX 7 - Joget | COMMUNITY
    add a selectbox (field id: class) looking up your classes table in your user profile (form id:user_profile). Then use Form Binder Hash VariableHash Variable - Knowledge Base for DX 7 - Joget | COMMUNITY
    #binder.options.classes.name[{form.user_profile.class[{currentUser.username}]}]#
