I am running Joget on Windows Server 2019 Datacenter. I have turned on Debug for the JSON Tool. The tool is failing to insert the JSON Object Names into the Workflow Variables and I am trying to debug that. However, I cannot locate the debug lines in any of the logs that I have examined. Where should I be looking for them - Catalina.log, Joget.log, localhost.log - or where?
  1. William Vasu
    Solved! Restarted Joget and then could see and debug JSON tool!
    It will be in either catalina.out or joget.log
