Hi guys !!
1) I´m have an Status form named "Status" with id and description fields.
2) I´m have an form named "Ordem de Serviço", with an field named "Status" with Select Box with binder of type "Default form options binder" with Form options is "Status" form.
3) My form datalist created from form "Ordem de Serviço", display datalist from this form with the status collumn too (step 1).
4) I´m created an filter on this datalist "Ordem de Serviço" for field "Status", but it´s no working, returning zero rows on that datalist.
Configurations below:
Suggestions ?
Thanks,
Paulo Nascimento
      You don't have to drag and drop an id field. Joget autogenerates the ID column for you. There are some use cases that you might want an id field on the form. if that's the case, make sure you select the right id field in the filter > id column
      1. Paulo
        Hi Ian, thanks for your answer.
        But i´m not created an ID collumn. Form status have an unique field description text on your design.
        See image bellow
      2. Ian
        Mine works fine btw. Have a look
        APP_kb-1-20220914134816.jwa
        Using Enterprise Version: 7.0.32 - build 254ea81
