Hi, are you using the Import Menu? Did you try to enable "Use Formatted Value" in the Column Mapping?
Thanx alot Anders Now its Working
Thanks For Reply Anders
No i Don't Use Formatted Value I Will Enable This Time and Check Its Working or not
I have Import data from excel But In the DATE Field Show some differet Data I Mapped Data Proper
