Hi guys,
My question is : Joget DX Enterprise Oncloud executes  mutiple SQL commands ?
Form Feature:
Query
Edit Form > Advanced > Configure Database Update Tool > Query
Command:
update app_fd_conta_contabil set c_saldo_conta = c_saldo_conta - #form.pagamento_contrato.sum_pgto#
where ID = '#form.pagamento_contrato.cboCtContabil#';
update app_fd_ordemservico set c_cboStatus = 'Paga'
where ID = '#form.pagamento_contrato.txtIdOS#';
Exception Messages:
Caused by: java.sql.SQLException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'update app_fd_ordemservico set c_cboStatus = 'Paga'
3635
where ID = '3878fea0-f5a7-4a' at line 3
3636
Query is: update app_fd_conta_contabil set c_saldo_conta = c_saldo_conta - 253.40
3637
where ID = '5fe076fd-6081-40a9-9695-e5f3dc06e52c';
3638
3639
where ID = '3878fea0-f5a7-4ab6-9f8f-64beab411bd2';
Paulo Nascimento
      It depends on the JDBC driver used. Normally, it is safe to assume it does not. You should use multi tools and point to a Database Update Tool for each query.
      I think your problem is that 'c_saldo_conta' is a string, so, you cannot use operator arithmetic minus.
      You should cast it first to number before performing arithmetic operation.
