I want to post data which is a list grid in form, but I searched KB in community, it is over my head. So how should I set the json param in json tool ?
      Assumption:
      Form A contains list grid
      List grid is coming from a Datalist
      Datalist is coming from Form B
      Form B should have hidden field called parentId
      Form A the list grid is configured to use multirow form binder and sourced to FormB and parentId
      Create a process with 2 JSON tools
      Tool 1 : store to Form A
      Tool 2 : store to Form B, add 1 more param: parentId = #form.FormA.id#
      should work.
        Hi, I assume the list grid data is stored in a separate form table? In this case, you can try using the hash variable Hash Variable#FormHashVariablebyIndex.
