Validator (Bean Shell Validator)
Configure Bean Shell Validator-- Script
Unable to run JavaScript in Bean shell validator in Joget Dx7. Please help on this issue.
      You can use Custom HTML form element to run the javascript. See Custom HTML
      Front End Validation example of  using javascript in custom HTML
        Beanshell should be filled with Java code (not javascript).
        Reference: Bean Shell Programming Guide#UseasFormValidator
