css code: V6 V7 are same,they were no effect.
body select:not([class^="ui-"]):not([multiple]):not([size]) option, body .editor-cell select:not([class^="ui-"]):not([multiple]):not([size]) option {
     cursor: pointer !important;
  1. Bastiana
    Maybe you can explain the use case, attach a screenshot on what you are trying to attach. It is hard to imagine what previously worked.
