Hi, there,
in datalist hyperlink I defined several url parameters.
It works in Desktop but fails in Mobile, as you see the param values are missing.:
http://192.168.177.99:8080/jw/web/mobile/mes/ProdOrdUI/_/EditPO?&id;fk_POId;navi=
Can you check that?
Thanks!
      Thanks for your info. It is confirmed a bug and it is fixed. The fixes will be available in next release.
        Hi, Owen
        Thank you for the answer.
        If this is a disabled feature in community edition, it should be disabled completely.
        In mobile each list item is still hyperlinked and clickable, however,  the result is an empty form.
        the screenshot below is a list item, the hyperlink address appears when mouse hover. and the "gear" icon on the right is also hyperlinked with different address. the result of 2 links is an empty form.
          Can you provide a screenshot? As I know the mobile view having limited feature. It remove all the filters and actions when it is in mobile view. So I am not sure how you got that link. If you want full datalist feature in mobile, you may need to consider the new Janux theme in v5 which support responsive layout.
