I was trying to install Joget workflow v4 community edition in a Windows computer using the Windows setup wizard. In the screen for choosing components, the check box for 'Joget Workflow' is disabled. Only the check box for 'Start Menu Shortcuts' is enabled. I am using Windows 7, 64 bit with 4GB RAM and more than 8 GB hard disk space. I am able to install it successfully in other computers.
Thanks in advance.
      The option for Joget Workflow is greyed out but checked because it is a mandatory option. You should be able to proceed to installation as per normal.
