I want to know if there is a way to export the running processes while exporting the application?
I recently migrated an app from 1 server to another and all my process have been terminated which is causing a big issue!!
      Hi, if you want to move actual running processes as well, then you will need to perform a proper backup and restore of your installation as per Backup, Restore and Disaster Recovery#MigratingtoNewServer.
