Dear Team,
I am facing problem in JavaScript, i have two radio button option called "Days" and "Hours".
when we press the Days it should use this formula for calculate the Days
 $('input[name="from_date"], input[name="to_Date"]').change( function(){
      d1 = $('input[name="from_date"]').datepicker('getDate');
      d2 = $('input[name="to_Date"]').datepicker('getDate');
      diff = 0;
      if (d1 && d2)
            diff = Math.floor((d2.getTime() - d1.getTime()) / 86400000)+1; // ms per day
      $('input[name=Enter_Number_of_Days_Hours]').val(diff);
and when we click on the Hours i want to clear the text from this ID "Enter_Number_of_Days_Hours" so that the user can enter the number of hours .
can you please help me with JavaScript for this. as i have tried all the place could not find the suitable solution for joget
      Hi Dear,
      I have applied your solution but still when i click on the radio button it dose no clear the text from the field.
        you can use jQuery to achieve this. below is sample code, please modify it according to your requirements
        $('input[type="radio"]').click(function() {
            // Get the value of the selected radio button
            var selectedValue = $('input[type="radio"]:checked').val();
            if( selectedValue == 'Hours') {
        	  $('input[name=Enter_Number_of_Days_Hours]').val('');
            console.log(selectedValue + " selected");
        Hopefully this will resolve the issue.
