In JogetDX 8 when I imported from 7 the Userview names and icons changed to the app name. How do I change them back to the Userview names?
      Hi, did you try changing the userview name directly in the UI Builder? In the UI Builder, click on the UI title on the top left and you should be able to edit it.
      1. William Vasu
        Anders,
        I just tried that. Although the Userview names were already the correct ones, I did retype them and saved them. However, the names in the App Center icons remained as our app name not the userview name.
