how will i host this app into a local intranet? what do i net? can someone tell me a step by step prcodure so i can upload this to our network and we can start using it. thank you in advance!
best regards,
Jedi
      There are a lot of information on Joget Workflow installation in the Joget Knowledge Base.
        You would want to install it on a server in your local area network, unless you want users to access your PC (wink) This discussion might help http://stackoverflow.com/questions/14036859/how-to-access-tomcat-from-another-computer/14048153#14048153
        1. jedi
          and with me installing it to the local area network. i can restrict them by just accessing the project i made. not the whole joget?
        2. Anders
          If you mean server or network level permissions then you need to research and learn those areas. On the Joget Workflow platform itself you can control permissions following https://dev.joget.org/community/display/KBv5/Permission+Control.
