Hi all,
I am trying to Build Source Code on Windows with 8.0-SNAPSHOT and currently am hitting this error upon mvn clean install:
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.0.2:compile (default-compile) on project wflow-core: Compilation failure
[ERROR] C:\Users\User\joget_src\jw-community\wflow-core\src\main\java\org\joget\apps\app\dao\GitCommitHelper.java:[12,27] error: cannot access Git
Please help to advice.
      Hi Anders,
      I am using Java Version 8 Update 371. Is this why I am hitting this error?
        Hi, what version of Java are you using? I'm able to build using Java 11 LTS
        1. Harita
          Hi Anders,
          I am now using Java 11 now and still hitting error: cannot access Git.
          java version "11.0.19" 2023-04-18 LTS
          Java(TM) SE Runtime Environment 18.9 (build 11.0.19+9-LTS-224)
          Java HotSpot(TM) 64-Bit Server VM 18.9 (build 11.0.19+9-LTS-224, mixed mode)
