I have a trouble deleting the field in database of joget, because i delete the field on the form already, meanwhile in database it not deleted the field (column), i use query to delete in database and its work, but the next day i reopen the database again and i see the field (column) appear again.
Please assist me if have any suggestion..
Thank You.
      The reason the DB column reappear after deleting is because the field is still defined in one of your forms. Do check ALL your forms to ensure that field id/column is not in the form anymore. Also check ALL versions of the app, meaning the app version 1, 2, 3.... and so on.
