Why below error show even i enter 10-05-2016
  1. Walter
    Can you give me steps to replicate so that the community can help you?
  2. Saravanan
    There are 3 field need to update in my FORM 1.Service By: Date 2.Acknowledge by: Date: 3.Witnessed by: Date: When I tried to select same date as "Service By Date", system show error invalid
  3. Walter
    I don't think I can do anything to help you with the information that you just provided. Based on your information, I need to create 3 fields in a new form with those labels you provided. What's next?
    There's not enough information provided to understand your question. You might want to read and follow this guide from StackOverflow http://stackoverflow.com/help/mcve
      When I choose date for example : 12-05-2016 from date picker, system show error Invalid date format , value need to be after or on 12-05-2016
      1. Anders
        Hi, how is your app designed, and how can the problem be reproduced? Without such information, can't really help you. Best if you refer to http://stackoverflow.com/help/mcve on a good way to ask for help
