Hello,
Could somebody help me with the userview inbox. It doesn't show how many message come to the inbox as picture 2 below
Picture 2
Thank you
      Hi Thang
      In Userview>Edit Datalist Inbox>UI, you need to set this field "Show Number of Rows in Menu" to tick yes in the checkbox.
      If you are using CRUD, its the same checkbox in Userview>Edit CRUD > UI (List).
      For list, its is in Userview>Edit List > UI.
        Hi Matthew King,
        Thank you for your great help. It works for me.
