e.customProperties.createdBy = '#currentUser.username#'
does anyone have an alternative for this expression that actually works ?
  1. Anas Misbah Shami
    Please tell me where you are using it. It should work
    Which binder are you using?
    if you can upload a screneshot, that would be great
    Hi, if e.customProperties.createdBy does not work, you could try e.createdBy . Alternatively, instead of writing code using BeanShell, you could try configuring the condition graphically using the Advanced Form Data Data Store.
