You can get the CSRF token name and value using the following method then post it together with other data.
There are SecurityUtil.getCsrfTokenName and SecurityUtil.getCsrfTokenValue method allow you to retrieve the token. You can implement a secure api to retrieve it and use it in your project.
If you still want to disable it, you can change the value of "org.owasp.csrfguard.Enabled" to false in Owasp.CsrfGuard.properties file under "[tomcat directory]/webapps/jw/WEB-INF/classes".
