Following Code is not working in V5.
FormDefinitionDao formDefinitionDao = (FormDefinitionDao) AppUtil.getApplicationContext().getBean("formDefinitionDao");
FormService formService = (FormService) AppUtil.getApplicationContext().getBean("formService");
AppDefinition appDef = appService.getAppDefinition(appId, appVersion.toString());
FormDefinition formDef = formDefinitionDao.loadById(formId, appDef);
if (formDef != null) {
    //create the form
    Form form = (Form) formService.createElementFromJson(formDef.getJson(), true);
With Following Exception. Do we have any change in the class.
ERROR 14 Jun 2016 12:37:20 org.joget.apps.app.web.JsonResponseFilter  - java.lang.IncompatibleClassChangeError: Found interface org.joget.apps.form.service.FormService, but class was expected
        at webservice.JsonApiPlugin.getFormImageFields(JsonApiPlugin.java:395)
Try to do it this way but still failing
    FormService formService = (FormServiceImpl) AppUtil.getApplicationContext().getBean("formService");
      In v5, FormService had been changed to an interface with FormServiceImpl as its implementation.
      I can't replicate your issue. From the error you posted, it could be you are building your plugin with v4 source code?
      The following still the correct way to retrieve FormService.
        I am able to resolve the issue by compiling the Code with V5 dependency
