tried to refer to this page for bean shell programming, but its not working, how do i check if the user is from a certain department and not allow them to view certain category in userview
import java.util.Collection;
import java.util.Map;
import org.joget.directory.model.Department;
import org.joget.directory.model.User;
import org.joget.directory.model.service.ExtDirectoryManager;
import org.joget.workflow.model.service.WorkflowUserManager;
import org.joget.workflow.util.WorkflowUtil;
public boolean isAuthorized(User user, Map params) {
    //if no logged in user
    if (user == null) {
        return false;
    ExtDirectoryManager directoryManager = (ExtDirectoryManager) AppUtil.getApplicationContext().getBean("directoryManager");
    Collection department = directoryManager.getDepartmentByUsername(user.getUsername());
    if(department.equals("Legal")){
        return false;
    }else {
        return true;
The error im getting is error executing script.
      Use https://marketplace.joget.org/jw/web/userview/mp/mpp/_/vad?id=not_permission-v1 then choose the department. Anyone else other than users in this department would be permitted to access.
      1. Di Sheng
        I saw the supported SQL is only MySQL, would it be compatible with MSSQL as well?
