Hello im still new and i want to develop a plugin for Radio to make an update to database every time the option selected.
Can anyone tell me which plugin type i should extends or implements?
and if i want to create a option value and label on the code how i do that.
      Apparently if you extends Radio, no need to implement FormBuilderPalleteElement anymore. You can extend Radio class, but you need to override some methods: getName, getLabel, getClassName, and most importantly renderTemplate. And you need to copy implementation of radio.ftl and adjust accordingly.
      How are you going to update the data? I suppose by using ajax.
