The process is after user submit the pc_maintenance_form,user will get e-mail notification for rating
When I run the process, I get the e-mail notification after pc_maintenance form SAVE--->COMPLETE–>mail received
But when i SAVE the pc_maintenance form in Production, I did not receive activity to COMPLETE the saved form, in order to get rating e-mail notification
Is that anything wrong with the process?
      Hi Saravanan
      After you submit the form, check if the process activity for this workflow is in "Monitor Apps>Running Processes" or "Monitor Apps>Completed Processes"?
      If the process is not there, most likely you didn't use the userview menu "Run Process" to start the process form.
      You could have used a normal "form" menu to display the data entry form, and because it't not a "Run Process" action, it won't start the process activity. Thanks.
      1. Saravanan
        Hi Mathew, Thanks, its working fine now :P
      Hi Saravanan
      Did you add the "Map Participants to Users" for rating?
      Cheers
      1. Saravanan
        Hi Mathew, Already add but still no nothing found in activity list
