How to auto CAPS LOCK in form, whenever user update in small caps
Kindly share where to update
      You can use JavaScript and/or CSS to achieve this. Add a Custom HTML element into your form and add the relevant JavaScript/CSS there. There are many resources online if you search for it e.g.
      http://stackoverflow.com/questions/15163570/how-can-i-change-all-input-values-to-uppercase-using-jquery
      http://stackoverflow.com/questions/5757101/change-input-to-upper-case
        Alternatively, you can use CSS to format the fields -http://www.w3schools.com/CSSref/pr_text_text-transform.asp
          Hi Saravanan
          One way is to write your own plugin for a new text field element with built-in uppercase setting.
          Alternatively, you can use Javascript to uppercase the field element before saving the form.
          1. Saravanan
            Hi King, Which field element i should update in my form, kindly please share with screen shot
