How to do drop down sub-menu in user view
Example: Under DTRS e-form (main menu) there are 2 (sub menu) DTRS Portable e-form and DTRS Base Set e-form
      I think you will need to switch the Userview theme. The only theme that I know will be able to simulate a sub-menu is the Janux theme. Or develop a new Userview theme. Good luck.
        Hi Saravanan
        You can add this text "   DTRS Portable" to indent it to look like a submenu.
