Dear Expert,
Can anyone provide some sample code with the following WorkflowManager Methods
1) getRunningProcessList
2) getProcessVariable
3) processAbort
Best Regards
Tony Chu
      Hi, you can search for those method names in the GitHub repository https://github.com/jogetworkflow/jw-community. You should be able to see actual code that makes use of those methods.
        Hi Tony
        The Joget Knowledge Base has tons of documentation on Joget Methods and Beanshell Programming.
