Hi All!
I need to export by cron job or by ssh form data. Either csv, pdf, xml or excel version?
All I can find is Export data or related with the user log in!
Is there a way to do this in Joget?
      Hi Peter,
      You can probably achieve what you want by simply creating a script to export the respective app_fd_* table from the database you use. (unless you are on cloud.joget.com)
      There should be a number of scripts you can find on google / stackoverflow regarding scheduled export of tables from f.e. mysql to csv or xls.
      I hope this helps,
      Eric
        Hi Peter,
        May be you can consider create a datalist and use the export link under the list?
          Hi Eric,
          That's what I'm doing but I wanted the pdf repport. So I don't have to recontruct whole thing...
          The problem from the database is that  for one particular repport I need multiple table extractions.
          I thaught it was possible to connect and access the app from /php or cli and request the pdf version or the xml version.
          Do you think of a way to do this?
