Hi Firdaus,
You need to use AJAX Subform for that.
Check out this link for its guide and tutorial: AJAX Subform
Thank you for your recommendation; it solved my problem
Hello Forum Members,
I'm working on a project where I need to create two forms: a template form and a secondary form. The template form will collect specific data, and I want to use this data in the secondary form without manual input.
Template Form:
![](/community/download/attachments/258278555/1.JPG?version=1&modificationDate=1698743465000&api=v2)
Using Template Data in Secondary Form:
![](/community/download/attachments/258278555/2.JPG?version=1&modificationDate=1698743465000&api=v2)
I want the data from the spreadsheet appear in the second form spreadsheet after select template id form the Select Box.
I appreciate any advice, tips, or resources you can provide regarding creating template forms and utilizing template data in a secondary form. Thank you in advance for your assistance!
Best regards,
Mamat
