you pass return first that why is not reach to con.close () linn
try this code
public FormRowSet getIslas() {
FormRowSet f = new FormRowSet();
f.setMultiRow(true);
Connection con = null; // declare the connection variable
try {
DataSource ds = (DataSource) AppUtil.getApplicationContext().getBean("setupDataSource");
con = ds.getConnection();
if (!con.isClosed()) {
String recordId = "#currentUser.lastName#";
String sql = "SELECT c_firstName, c_username FROM app_fd_registration WHERE c_username=?";
PreparedStatement stmt = con.prepareStatement(sql);
stmt.setString(1, recordId);
while (rs.next()) {
FormRow r1 = new FormRow();
r1.put("nama_syarikat", rs.getString(1));
r1.put("id_pemohon", rs.getString(2));
f.add(r1);
} catch (SQLException e) {
// Handle SQLException
e.printStackTrace();
} finally {
if (con != null) {
try {
con.close();
// Handle SQLException while closing connection
return f;
This is my code for jdbc load data binder. But i dont know why joget log keep response possible db unclosed. Is there any problem with my source code?
import java.sql.*;
import javax.sql.DataSource;
import org.apache.commons.collections.SequencedHashMap;
import java.util.*;
// Connection con = null;
DataSource ds = (DataSource)AppUtil.getApplicationContext().getBean("setupDataSource");// add this
con = ds.getConnection();// add this
if(!con.isClosed()){
String recordId = "#currentUser.lastName#"; // Get the url parameter
String sql = "SELECT c_firstName, c_username FROM app_fd_registration WHERE c_username=?"; // Here you can query from one or multiple tables using JOIN etc
while (rs.next()) {
f.add(r1);
return f;
con.close();
return getIslas();
