When Uploading Joget Hedera Plugin on the latest downloaded joget i get an error
(&(osgi.ee=JavaSE)(version=17))]
And to resolve this I need to change my Joget and install JDK 17 apparently.
Can anyone assist me on how can I do it?
      Hi, the error says that you need Java 17. The Java configuration depends on the app server you are using. Assuming you are using Apache Tomcat, I believe the easiest method is to set the JAVA_HOME environment variable https://stackoverflow.com/questions/63117732/how-to-change-java-version-for-apache-tomcat-9
