Joget has an IDP based soloution for ADFS SSO described here
https://dev.joget.org/community/display/KBv5/Joget+Workflow+SharePoint+SSO+Integration
Does joget has any SP based Solution more commonly used then IDP.
Or any Easy way to achieve it?
https://blogs.oracle.com/dcarru/entry/sp_vs_idp_initiated_sso
Jahan Zaib
Open Dynamics
      Can't you create a web filter on Joget for this? You could initiate a login redirect to the IdP and add the authentication result to the Joget's session object?
      Hope this helps!
