Hi, I have installed joget as window service by installing tomcat and Added MySQL service as a Dependency to Tomcat service with existing mysql database which i am using for other application. every thing is ok but while starting joget, i am getting error-13 (slow-log) generating from inside joget mysql. Please help me i am very new to this application.
appreciate for your kind support...
Nagendra
      Error code 13 indicates that the user that you use to connect to MySQL database doesn't have enough permission. I hope your MySQL DB is also in the same windows machine. If it's on a different Linux server, then you need to have permission to modify the db file.
        Good news! After months of intensive development, we're proud to announce the beta for Joget Workflow Version 6 is now available for download at http://www.joget.org/joget-workflow-v6/#next
        Read what's new in Joget workflow Version 6 at http://www.joget.org/joget-workflow-v6/
