Hello, I'm looking for some solutions to manage workflows and documents (generate and attach). So I'd like to know if there's something in Joget that i can use for this.
      Hi, you can make use of the Export Form Email Tool to generate and email a PDF version of your forms, or you if you need a more customized layout (e.g. for certificates and such), you can try using the JasperReports plugin. If it doesn't suit your needs, you can always develop your own custom plugins i.e. Extending Functionality - Developing Plugins.
