I have multiple forms in my Joget app: NC, CN, and Units. The form fields are as follows:
  • NC Form Fields: ID, Command Name, Command Code
  • CN Form Fields: ID, Control Rate, Command, Location
  • Units Form Fields: (Please specify the fields for the Units form)
I want to dynamically display CN records under their corresponding NC records on a Joget UI page. For example, if I enter the following records:
  • NC Records: SNC, WNC, ENC
  • CN Records: CN SNC, CN WNC, OF WNC, CN ENC
I want the UI to display them as follows:
  • SNC
    • CN SNC
  • WNC
    • CN WNC
    • OF WNC
  • ENC
    • CN ENC
Please provide the necessary HTML and JavaScript code to achieve this functionality within the Joget UI Builder.
      Hi, you could try using the Nested List Formatter to see if it meets your need.
      1. K Raveendra
        its not working
