i have 3 column in 1 section .  and i want hide field in some column .
is possible to add section on column or there other ways ?
for example.
example 1 = column 1 and column 2 i want hide field on red box . but for column 3 still visible.
example 2 = i want hide field on column 3 on red box. but column 1 and 2 still visible
      I'm only aware of Show and Hide Form Sections (Section Visibility)
      But if you don't need to rely on a field's value, then you can write some CSS or JS to hide them yourself.
