How can we increase time for a Joget login user, by default if session is inactive for a few min it automatically logout.
Regards,
Touqeer
      Hi, it seems to be something else causing your logouts because by default the session should not timeout if you have your window open. You can change the timeout settings using the Security Enhanced Directory Manager.
