i already try load binder used bean shell or load binder . the both way have same issue when load on form grid
because sometime the button edit or delete is kinda stuck in record id 1 just like red box. but sometime is right like green box. how to fix this issue so didn;t go like red box
this is example value from load binder
      Hi, what version of the Subform Repeater plugin are you using? Perhaps you can try the latest release to see if it solves the problem.
      1. galvin
        i already uninstal version v7.0.2 and instal v7.0.4 . but still same issue . and add info my joget version is 6.0.15
