From a datalist row field I access a corresponding detail form via hyperlink with id param. It opens the form, but the record data is not show. First field on the form is the corresponding (non editable) id field with the value passed thru id param. The cursor is put automatically in the second field, which is a contact name. The record data is not shown and was probably no read/retrieved. Where do I go wrong?
  1. Anas Misbah Shami
    Can you send hyperlink configurations?
    Hi, are both the datalist and form configured to point to the same database table? You can try to refer to the sample CRM app in the Community Edition to see a similar working configuration.
