Hi, this should be done automatically by the binder. What version of Joget are you using? If it is a really old version then there might have been updates since then.
i have issue on mysql "too many connection " when i check the db didnlt close connection after i use jdbc binder custom datasource. how i can disconect after i call the db ?
