Hi, there is not enough information. For your info, the #requestParam.id# hash variable is the value of the "id" parameter in the URL.
i have issue when call default value on textfield with #requestParam.id# . because when i try add new row the value #requestParam.id# didn;t get call .
Sorry your question is unclear.
Are you saying the the form data is not loading with #requestParam.id#?
You can't use #requestParam.id# because it may be pointing to the same value all the time which is the parent form record ID.
