If you want to do it before you submit the form then you will have to use jquery.
If you want to send the data after submission then you can use a post processing tool to update the field 2 value using form hash variable (#form.table.field#)
ok thanks for the info
i have 2 field with id field1 and field 2.
field1 i input "test"
so is there hash variable so i can get value from id field1 and send to value field2?
